REVOLVE
I was wondering if someone could shed some light on a revolution for me?  I want to revolve this hammer handle 360 degrees but I made a mistake and only revolved it at 180 degrees.  How do I go back in and edit it to a 360 revolution?  Thanks for any help.
TRC
Re: REVOLVE
Hi there @TRC,
Your part is modelled in Synchronous, which is, for the most part, "history free"....but you have an option to complete this easily,..simply select the "Revolve" in the feature tree, this will select the whole bodyy, then use the "Mirror" command, and you're done.
Here's a video of it....I slowed my steps down to make sure you spotted what I did & where the part & tool selections are being made.
(view in My Videos)
Solid Edge ST10 [MP7] Classic [x2 seats]
