Radial Menu Not Showing
I started to work with drawings in assembly as well as sync, noticed the radial menu is not being shown. Reset back to default setting.. In the radial menu SE options the minimal setting is set for 50 max. setting 400.
Tried a new drawing same issues.
Thank You
Greg
