Radial Menu not Showing
Good Evening,
I was working on an installation on an another site.  The installation had a blurb... SE followed with the same blurb. I was working on the document, noticed the Radial Menu will not show. Saved doc cut off SE, tried to possibly set on customize the radial menu. No luck with either. I'm interested in a possible fix.
Thank You Very Much
Greg
You might have to clarify a few things, like what's a blu...
MLombard
Retired
You might have to clarify a few things, like what's a blurb? Do you mean you had an error while installing Solid Edge software?
The only settings for the radial menu  I'm aware of are at the Application Button > Solid Edge Options > Helpers > Radial Menus.  If the minimum drag distance is too high, or the Show Radial Menu After setting is too long, you might not get radial menus.
