Radial lines
Not applicable
Hi
I need to draw a number of radial lines (130 for example) within a circle.
I attempted this with the bolt hole circle, without success.
Any clues
Geoff
Re: Radial lines
Geoff,
Place the first line. Click on the line to locate it. In the drop list under the Mirror command, click on the Circular Patern command. This should allow you to place as many lines around the circle as you need.
Rick B.
Re: Radial lines
Not applicable
Rick
Many Thanks.
Easy when you know where to find it.
Couldn't find it in the help.
Thanks again, great service.
Geoff
