Re: Where is the Scaling Ratio Fields
Not applicable
"Larry Walters" wrote in message
news:490b5a3d$1@bbsnotes.ugs.com...
> I've not been able to locate the feature to scale when importing from the
> 2D Model
> to the work sheet or to refine the Scale on the work sheet.
> Anyone come across this yet?
> Larry
> Iceman
Not applicable
Forgot to mention that you can key in any scale value you want in the box
below the drop down. You are not limited to the values in the list.
David
"David L Rieschick" wrote in message
news:490b5b88@bbsnotes.ugs.com...
>> 2D Model
>> Larry
>> Iceman
Not applicable
I've not been able to locate the feature to scale when importing from the 2D Model
Larry
Iceman
Not applicable
Thanks David,
I missed this response till just now.
Larry
>> 2D Model
>> Larry
>> Iceman
Iceman
