Readjusting Text Profile
PLM World Member Builder PLM World Member Builder
On this video illustrates the letter (W)... First extruding up and past the cylinders. The letter W is shone whole before the set to a measurement. After the set measurement trying reset back to the original W, the extrusion the cylinder is still set in the W, I would like to reset back to the beginning W.Ater save.
http://screencast.com/t/AEdFbSMC
Thank You
This is one of those times when you need to transition to...
Esteemed Contributor
This is one of those times when you need to transition to "Ordered" mode, make the text, then back to "Synchronous".
This has to do with faces & features being consumed by the new, or modified, geometry.
Re: This is one of those times when you need to transition to...
Sean,
I have text on a lot of parts... which I used text syn mode for all. Am I
to redo! Because I've tried the ordered mode and the syn mode completely
struck out. Any suggestions!
Thank You
