Reducing the scale of a part.
Hello All,
                        I have  Helical gear thart I want to reduce in size,  ie scale it down by half.  I opened a new blank part workspace then part copy and this is where my problem comes in.. I can scale it up but what is the procedure for scaling down ?
I tried uniforn scale at -.5 but get the message saying the number must be greater than zero [ or some such message ]
I did try the following equation 1-2=-1  but no joy.
Maybe it is not possible to reduce a part only enlarge it.
Raymond.
Re: Reducing the scale of a part.
Hi @inconel
Avoid using a negative value.
Just try using 0.5 for scaling down by half.
@Tushar  Sorry for the late reply, did as suggested and scales down perfectly.  I previously tried every formula I could think of  except the obvious one.
Many thanks with this.
Raymond.
