Referring to %VA or %AS in callouts?
Hello all,
I hope I'm posting this in the right board.
Is there any way I can refer to information from a section or detail (i.e. %VA or %AS) in a callout?
I will often assign a name to a dimension and refer to it in a callout, for example: "3 PITCHES @ %{DIM01|V} = %{DIM02|V}".  Is is possible to treat view annotations in the same way so that the annotations update when the view annotation is changed?
Many thanks!
Murray
Re: Referring to %VA or %AS in callouts?
PLM World Member Master PLM World Member Master
John J Bazaar
Mgr Development & Technology
ACI Services Inc
Thanks for your reply John, although I probably wasn't clear enough with my original post.
When a section or detail is assigned a letter (i.e. DETAIL A or SECTION B-B), is there any way to refer to the letter from a callout?
Cheers.
Not that I'm aware of.
John J Bazaar
ACI Services Inc
