Regarding representation of dowel hole in drafting
Builder
Builder
is there any facility to show dowel symbol in drafting automatically, as option is avaliable for "Dowel" in "Hole" command in 3D model
I am Using ST10 version.
Somnath
Somnath Pore
Univision Automation
Re: Regarding representation of dowel hole in drafting
SE is still behind the SW curve on this. But here is presented an SE style solution.
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Dowel-hole-symbol/td-p/345629
I'd suggest possibly making a block of that symbol, if you don't already have one, for easier insertion. You may need to scale it according to your hole sizes.
Bruce Shand
Builder
Builder
I am already using same method for this.
Somnath
Somnath Pore
