Reinstall/Uninstall failing
Hello! I am trying to reinstall ST10 Student edition to a new hardrive but I am getting errors. I have followed this post here :
https://community.plm.automation.siemens.com/t5/Solid-Edge-Student-Edition-Forum/unable-to-launch-So...
But it is still only giving me the repair and uninstall options when I re run the setup. Any help is greatly appreciated!!
Betreff: Reinstall/Uninstall failing
Esteemed Contributor
Hi @Petermarcellas
and what if You first uninstall SE completely, clean up all entries in registry, %appdata% and then do a new installation?
Will this work?
Wolfgang
That is the issue. From the control panel add or remove program the uninstall process will not finish and returns we this error. Just like when I try to repair. So I have remmoved all appdata files and registry inputs lited in that post and still asks for repair/uninstall when runningthe setup.
Untitled.pngHere is the error I am receiving when trying to uninstall from tghe control panel. Those files have been removed manually so this may not be the original error message.
