Related with one Relationship?
Think i heard about this awhile back. i just related a part with one relationship. why would this happen?
Re: Related with one Relationship?
Honored Contributor
Honored Contributor
If a cone  was mated to a cone, that defines everything.
Esteemed Contributor
Was it set that way, with "Capture Fit" maybe?
it's not a cone. this part was just made and inserted in. no capture fit....wierd
No, there is also a fixed axial alignment needed.
I have seen this bug also. Suppres the relationship, make the other needed relationship(s) and unsuppres the firt one. This worded for me.
Solid Edge ST10 & AutoCAD 2018.1 user
I've seen this as well. Saving, closing, and reopening will often times also change this incorrectly fully constrained situation.
-Dylan Gondyke
When relationships constrain a part before it should be constrained, I check the Error Report for other parts that have failed relationships. If there are failed relationships on other parts of the assembly, I fix or suppress those. Under-constrained parts are ok, just look for failed or unsatisfied relationships.
Keep in mind that the solver is trying to simultaneously solve all assembly relationships, not just the new one you are adding. Conflicts anywhere in the assembly can cause issues.
HTH,
Jason
