Relationship assistant problem
Hi everyone,
I ask your opinion using the assistant relationship command in dft environment (2D model)
I have a series of lines (test1.dft) to which I apply the command relationship assistant , and for now everything is right, if I try to do the same thing with few blocks (test2.dft) the process is few seconds longer and relationships are bugged (relation bugged.jpg) if I try to drag them they are not constrained.
Where am I wrong???
Have you ever noticed this thing???
Is this the right way???
Solid edge operate is correct ???
Thanks everyone
Alex
Betreff: Relationship assistant problem
Esteemed Contributor
I can not see any difference between draft 1 or 2.
Both will get the same result after running the relationship wizzard
I use ST9 MP1
Wolfgang
You're in right, i try with your config and the result looks better(in ST8 the problem remains), but still I am not persuaded,
Can you do something for me and try again with the file test2bis.dft???
Thanks for your help
Alex
Hi Alex,
for me it looks like OK
Wolfgang
