Relationships In Synchronous
maybe this seems a daft question..
but do I need any other relationships in Synchronous other than Ground when compiling a GA assembly model ??
If I do why??
8 REPLIES 8
Re: Relationships In Synchronous
I don't quite understand your question, nor the term "GA assyembly".
Can you expand a bit please.
are you asking about grounded faces in a Sync model or Ground relationship in an Assy?
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Betreff: Relationships In Synchronous
@DADDY-G
... Ground when compiling a GA assembly model ...
An assembly by definition is wether Synchronous nor Traditional, it is what it is, an assembly!
And what does it mean "Compiling a GA asm"?
Wolfgang
GA = General Arrangement?
CAD/CAE Manager
SE2019 MP5
Hello Matt
GA = General arrangement..
Ground relationship in an assembly..
Hello Hawcad
Thanks for your reply.
So creating an assembly in Synchronous is the same as in ordered??
yes.   no different.
Matt Johnson
Teamcenter 10.1.7
Hi @DADDY-G
Yes, thee is no difference any mor since ST4
From St to ST3 there were different templates for ASM too, but for longer than 6/7 years there is nothing else different in ASM in order which type of part You are assembling.
Only when change geometry within a part or create geometry direct for a part You can see that SE is working slightly different.
But not for how to bring parts into an ASM
Wolfgang
Matt & HawCad
Thanks for for your replies...
I'm used to working in synchronous as opposed to ordered but I have been asked to
do some modelling in ordered and just wondered if there was a difference between
both enviroments in assemblies as well..
Thanks again..
