Remove Stud.
Builder
Builder
So I found this sheet metal file but there is a stud in the part? I need some help removing it. Any suggestions? Im not too familar with removing faces, etc.
D.L.B.
Re: Remove Stud.
can you save as parasolid and repost?
i only have st6 at this time .
Re: Remove Stud.
Very easy in synchronous. In ordered you could cut it away but it will leave those cuts as features in the pathfinder.
For synchronous right click on the body feature and "move to synchronous". Put a window around the stud and hit delete. Done.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
Re: Remove Stud.
Builder
Builder
Is this what you want?
Re: Remove Stud.
Hi there,
I ran the "Optimize" command [on the Inspect tab] prior to deleting the faces that made up the stud.
Solid Edge ST10 [MP8] Classic [x2 seats]
Re: Remove Stud.
yes, thanks... but it appears that Sean may have already solved your issue in native st7...
good luck
Re: Remove Stud.
agreed,
i opened the parasolid (st6) into a sync part.  fence selected the pin and simply hit delete...
Re: Remove Stud.
Sean,
'I ran the "Optimize" command [on the Inspect tab] prior to deleting the faces that made up the stud.'
What did that gain you?
Bruce Shand
Re: Remove Stud.
Actually, only my personal sanity.....every time I see an error in the feature tree, I simply MUST clear it. Robot Embarassed
Seems if you start deleting the stud faces the error clears during the process.
I didn't bother with a Synch method, as the file was alread in Ordered.....so stuck with it.
Re: Remove Stud.
What do you mean by "deleting the stud faces"? Something other than cut features?
Bruce Shand
