Renamed One Temp Folder
I renamed one of the temp folder,  I've noticed the multiple subassembiles had some parts were missing with a File Folder Failure Notice. Is there an easier way of saving the subassemplies, without redoing your work using Replace Part.
Greg
Re: Renamed One Temp Folder
Use Revision Manager to relink or move files, rather than renaming or moving the folder in Windows.
-Dylan Gondyke
