Renaming Parts in Stp and 3d PDF files
Is there a fast way to Rename parts for stp and 3D pdf file either before or after creation.
So as to protect enginerring knowledge please.
I am using ST7
Re: Renaming Parts in Stp and 3d PDF files
You can use "F2" rename command in assembly tree or change Document name formula becaus of part's names come from here to pdf.
Here is a short video:
BR,
Imics
Imics your solution works perfectly with 3D PDF's.
Now all I need is a solution for Step Files and i'll be a very happy Cad Man
