Rendering problem
Hello
I have a problem with Keyshot rendering. Even though I have a CAD file with all the parts visible in the Solid Edge window, when I try to render it with Keyshot, I am missing parts! And there are some unrealistic features too (attached images)! Can anyone help me to resolve it?
Thanks and regards
Sunil
Re: Rendering problem
A couple of questions:
1. What version of Solid Edge and KeyShot are you using?
2. Do you have construction surfaces in your part that may be being rendered?
Thank you for your reply. Sorry for late response!
1. I am using ST7, academic version. Keyshot version is 5.3.
2. The lost surfaces are not construction surfaces. In fact, when I try to render the part separately, it renders correctly.
Thanks and regards
-Sunil
