Reorder reference planes in assembly?
Is it possible to reorder reference planes in the pathfinder in an assembly like you can in a part?
Re: Reorder reference planes in assembly?
No, it is not. This only works in part/sheet metal environments. While I have yet to encounter a need to rearrange the planes in the Reference Planes dropdown tree in an assembly (since it is for visual purposes only), you should submit an enhancement request through your reseller or GTAC for this. It seems like an obvious enhancement to normalize behavior of feature/history trees across environments!
-Dylan Gondyke
