Replacing a block in multiple drawings
Is it possible to batch replace a block in a set of drawings ?
Re: Replacing a block in multiple drawings
Since this involves a 'set of drawings' it calls for some kind of automation using programming.
I'd suggest you post this in the Solid Edge Developer Forum and see if someone can post some code and preferably a compiled version of it which you can use directly.
~Tushar
www.CADVertex.com
