Requested Relationship Conflict
I been seeing requested relationship conflict being an old assembly or a new assembly under Flash fit.  I then need to go to the next command with the steering wheel which is time consuming.
Any ideas?
http://screencast.com/t/ZiRgckFlTAmJ
Greg
Re: Requested Relationship Conflict
Any ideas?
Greg
Without seeing your Pathfinder and any additional relationships there may be, it is impossible to tell what the problem may be.
Greg
Greg, you REALLY need to show your whole Solid Edge screen if people are going to help you! This has been mentioned as an issue on almost every single video you post.
If you're holding down the Control key while dragging parts in, it will create a Ground relationship which will prevent you from building relationships to other parts. Once again, we cannot see if this is what you have done because we cannot see the assembly tree!
-Dylan Gondyke
