Reset Coordinate System Numbers
Good Evening,
With this video I would like reset the coordinate system back to zero. I looked into help no luck. Is there a shortcut?
http://screencast.com/t/pmyIDIyRvy
Thank You
Greg
Greg,   select the Csys from the pathfinder and then move...
Greg,
select the Csys from the pathfinder and then move it with the steering wheel. http://screencast.com/t/K4uJERAT
Why do you want to move these to zero and not just use the zero global csys?
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
