Retrieve dimensions for 2D model views
just tested the Solid Edge 2D license with ST9
When creating a 2D model view (pure 2D no 3D model envoled) and then a view on paper sheet, I remember that with prior versions it was possible to retrieve all dimensions from model view to paper view where all dims from auto-hide layers were retrieved using the correct scale
The function retrieve dimensions now is inactive.
Can anybody confirm this and ist this a bug or does this work as designed?
Wolfgang
