Reverse Engineering
Does anyone know of any basic tutorials for using the Reverse Engineering tools?  There is some help info but I can't find any worked-through tutorials with example part (stl) models.
Frank
Edinburgh University
Re: Reverse Engineering
Hi there @FrankMill ,
This detailed blog post might be of some help...... https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/An-example-of-literal-Reverse-Engine...
@FrankMill
I am drafting a detailed beginner tutorial on this topic and discussing with the forum manager and marketing.
It should be published by next Sunday on the community blog.
~Tushar
There seems to be a problem with the link @SeanCresswell provided.
Many thanks Sean, that is very comprehensive and useful.
I look forward to Tushar's tutorial too and I might make a simple one in the meantime. I'll post details if it's any good Smiley Happy
Frank
Tushar,
if you want someone to try it out in beta or otherwise test your tutorial let me know as I'd be happy to do so.
Best,
Frank
Hi Frank,
Thank you for offering to volunteer for the beta.
However, I finished it in one shot and the tutorial is now  live on the community blog in two parts, with 7 videos:
Also, I notice I could not keep my promise to publish it 2 weeks earlier, the process was too long with several videos to record, compose and embed in the articles. But I am glad I could pull it off.
Solid Edge Reverse Engineering Tutorial - Part 1 and Part 2
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/Reverse-Engineering-Tutorial-Part-1-...
Best Regards,
Tushar
