Revision Manager | Issue
I am trying to use Revision Manager option with SOLID Edge ST8. There is inactive option of  Set Path.
What makes this option not available? Please advise
Re: Revision Manager | Issue
Esteemed Contributor
It's not possible to know or even guess what's going on unless you show the entire rev man window.
Edit: There are other conditions where actions are greyed out even with files selected in the upper window.
Bruce Shand
It's when you select either Copy or Rename for the action
Set Path will be available after you perform one of the actions: Copy/Rename/Replace/Delete...
Yasser
Thank you for all your techanical support.
