Revision Manager library parts copy showing error for renaming, why?
Hi All,
I have problem in revison manager. (Requirmenet: Main Assembly need to copy for small changes)
In Revision Manager main assembly parts all copied to new location with new name (Parts which i created). But there are standard items added in assembly from library parts, when performing action i am getting (also see attached)
"files as the same as the original file. Please specify a different filename".
Here,
I don't want to specify new name. since I need same std parts in my new assembly also.
Please suggest how to resolve this issue.
Thank you all in advance.
3 REPLIES 3
Re: Revision Manager library parts copy showing error for renaming, why?
it appears that you have set an action to every line item.
Since you do not wish to copy or rename this item you need to "Clear Action" on this line item only.
I assume there may be other items as well,  a quick search by directory name might help yu find the others as well.
HTH
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Matt,
Thank you very much for your reply, i got it, i copied std parts then i selelct perform action, i didn't know about clear action.
Your answer is really helped me a lot.
Thanks.
@raju411
Great,  glad that got you quared away.
Please consider marking my answer as the solution so that others int he future can quickly find solutions when searching the forums.   thx much!
Matt Johnson
Teamcenter 10.1.7
