Ribbon Cable in Solid Edge
Hi all
We have a licence that allows the use of harness design. I want to create a series of ribbon cables in solid edge ST9 from connector to connector, any ideas? i dont want to bundle as a normal cable as the pin-board won't be correct.
Also I would like to introduce a standard strip back length for the wire. Is this possible to show in the drawing?
Any help would be great
Joe
Re: Ribbon Cable in Solid Edge
There is no way to design ribbon cable in wire harness module. You have to use part modeling environment. Smiley Wink
BR,
Imics
Siemens Legend Siemens Legend
Siemens Legend
Joe,
there was a discussion on this in the old Forum
http://community.plm.automation.siemens.com/t5/Solid-Edge-Sheet-Metal/modelling-ribbon-cables-with-b...
Good luck! /Ulf
Siemens EMEA GTAC Support
Just a suggestion:
BR,
Imics
