Roller Chain
I am trying to create a roller chain assembly in ST3.  I made a sketch for the chain path but not for sure how to make the links follow the path.
I found this video on YouTube, but they were using ST5 and I did not see the same relation they were using.
http://www.youtube.com/watch?v=XhCLACubMrI
Any help would be appreciated.
Hi,   Yes, because ST3 had not Path relationship yet.   I...
In ST3 you should use extruded surface instead of sketch and Cam relationship instead of Path relationship. It will work...
BR,
Imics
Imics
Re: Hi,   Yes, because ST3 had not Path relationship yet.   I...
Thank you for your help. That seems to be working so far.
