Rotate text box on drawing?
How do i rotate a text box so the text is at whatever angle i want it.
MagRiz
(ST9 User Est 01.18)
Re: Rotate text box on drawing?
Hi there @MagRiz,
There are a couple of ways to do this.....one; use the "Select - Properties" in the text box ribbon bar [image below]...or two; use your sketchtools, in this case, "rotate".
