Rotating a feature
PLM World Member Experimenter PLM World Member Experimenter
Is it possible to rotate the small hole, 45° CW?  If not, is it possible to rotate the angled plane or create one so the hole will be rotated?
Re: Rotating a feature
Community Manager
Are you using Synchronous? If so, just select the hole, reposition the steering wheel to be on the BIG cylinder and then grab the torus and rotate by 45 degrees -- keyin.
Dan Staples
