Rotating the Inserted Hole via Video
N/A
With this video... trying to insert the hole in the part, the hole lines up fine outside. When inserted the hole does not line up inside. Dealing with the plane live... (difficult to set). I what to rotate the hole to line up with the line. Any ideas?
http://screencast.com/t/lt1jC6KZqH
Crousie
Re: Rotating the Inserted Hole via Video
N/A
Crousie,
Your line is not normal to the tangent...
Thus a tangent plane give the bad result.
Use plane normal to curve and pick your line.
See Video. http://screencast.com/t/EuK5uP27ie
hth
