Rotional motor
Hello All,
I am struggling to simulate the leaves as shown in the attachement. I have tried to create rotational motor but thats works for the part only. It doesnt work for the patterned parts (11 patterned parts). Is there any way to rotate the leaves at the same time?
Many Thanks
Kevin
Re: Rotional motor
@Kevin1 wrote:
Hello All,
Many Thanks
Kevin
You will need to use ST8 to do this. When running the simulation in ST8, choose either the 'Active Assembly' or 'Active Level' option in the Update dropdown list on the animation editor:
This will run the simulation and update items such as patterns that aren't normally updated during the simulation.
Hope this helps,
Greg
Re: Rotional motor
Thast's brilliant.
we are moving on st8 next week can't wait to explore.
Thanks for your prompt reply.
Kevin
