SE 2D Organizing Blocks
I have a user that uses blocks for automating his weld drawings. Is there a way to sort or organize the blocks in the active documents so that they are in the ascending order?
Re: SE 2D Organizing Blocks
I do not believe there is...
Production: ST10 MP6
Testing: SE 2019
Thanks Ken, I was kinda thinking there was not an easy solution to quickly sort these blocks.
Thanks again. Jim B.
