[SE] [Synchronous Technology] [Cutting View ] Problem with sufrace sufraces marking in 3D part model
I am using SolidWorks usually. In SW we have Section View in 3D model. We can do crosssection in part environment using 3 planes or flat surfaces.
I have found similar function in SE: VIEW -> Cutting View. I can cat a solid using only one surface - please see printscr below.
When I move the cursor to the cross-section, the surfaces that should be cutted are highlighted - please see printscr below.
I would like to have easier way to mark surfaces behind the crosssection plane. Can we change that?
I did, I understand.
Re: [SE] [Synchronous Technology] [Cutting View ] Problem with sufrace sufraces marking in 3D part m
Hi @Father
You can easily  create a Section View using Sketch.
Regards.
Arek
Production: SE ST10 MP7
@arekkul Section View using Sketch is not avaiable in Synchronous modeling.
Hi @Father
but you can switch to Ordered being in Syncronous, create Section View and the go back to Sync, but in the Pathfinder (afted transition) you cannot see this unfortunatelly.
See my video
Edited: sorry have a issues with updating the video.
This is the link : https://youtu.be/LZ-6fwKidBA
@arekkul Video is not avaible. I tried: I can do Section View using Ordered, but when I go back to Sync I can not use  Section View.
HI @Father
no this is not true!
Cross Section View is available in Sync mode too!
It only is necessary - as always in sync - to have a sketch element there before creating the cross section view!
(view in My Videos)
Wolfgang
@hawcad Great to hear that. It works fantastic Man Happy
Hi @howcad
Thanks for that. I am not a Syncronous man, still in learning curve though.
Every day brings a new excitement.
Arek
