SE command for SnapshotConfig
Hi edgers,
although I have postet this question already in the programmers forum I want to ask here too, since there are a couple of highly qualified programmers online very often.
Can anybody give me a hint wether or not the snapshot dislay configuration in an assembly could be defined and retrieved by using api calls
I thought about SEApp.startcommand("command number") but was not able to find any info about that.
Thanks in advance and apologize my double posting in this case
Wolfgang
Re: SE command for SnapshotConfig
Spy for Solid Edge is a very great tool to discover this thing.
I don't know if there is a proper API method to do that anyway the command numbers are:
take snapshot = 10807
restore snapshot = 65290
Hi Fiorini,
thank You very much!
Exactly what I was looking for.
I know about the solid Edge spy, but wasn't able to neither find it on my machine nor here in the net
(Yes I know, searching in the net must be learned and trained)
Thanks again
Wolfgang
