SE crashing
Not applicable
SE crashes when I try to save. Please see the attached file.
Re: SE crashing
Is this file specific? Or every file?
Are you doing a Save or Save As some other file type?
Are you a new user?
Rick B.
Re: SE crashing
Not applicable
Hello Rick,
SE crashes when I try to save a blank document or if I work for a few minutes. At first I did get a low memory warning from SE at start up. I increased the paging file size until the memory warning went away but it still crashes. Could my PC memory be too low to run SE 2D?
Lee C.
Re: SE crashing
How much memory does your machine have?
What graphics card do you have?
Rick B.
Re: SE crashing
Not applicable
Celeron with only 0.5Gb of RAM and integrated graphics. What is the minimum required?
Lee C.
Re: SE crashing
Lee,
I assume you are running XP.
At least 1GB RAM is the minimum requirement. 2GB RAM is recommended.
Rick B.
Re: SE crashing
Not applicable
Hello Rick,
Thank you for the info. Looks like I need to step up the RAM in my old laptop to give SE a chance.
Thanks Again,
Lee C.
