SESP Workflow Issue
Hello everyone,
i have an issue regarding SESP workflow. please kindly advise
  • Within sharepoint designer, i have set the workflow and Publish globally
  • I have returned to my SESP, and tried to run workflow an ECR
  • The workflow is not available in SESP Sites
Is anyone here have such an issue? any advises will be very usefull
Thanks & Rgrds
Destian
3 REPLIES 3
Re: SESP Workflow Issue
Good morning Destian,
First question: What is your "Always_Use_Workflow_Cart" settings? Is it set to yes or no?
Second question: If your setting is "Yes", have you added your new workflow to the "Workflow Carts" document library? If your setting is "No", have you added your new workflow to the "ECR" document library?
Kind regards,
Theodore
Kind regards,
Theodore Turner
Solid Edge 2019 MP6
Teamcenter 11.3
Dear Theodore,
Thank you very much for your reply,
Based on my preferences,  the setting is set to "YES"
for your reference, the following is relation browser view
however, my workflow still empty.
Please advise,
Thanks You
Destian
Hello Destian,
What I actually would like to see is when you go to your "Workflow Carts" library and click on "Workflow Settings". What workflows are added to this library.
Theodore
Kind regards,
Theodore Turner
Solid Edge 2019 MP6
Teamcenter 11.3
