SIMULATION CANT DOING
WHAT HAPPEN. WHAT AM I DOING WITH WRONGLY.?Untitled-1.png??
Re: SIMULATION CANT DOING
Electron_Jaal87
you need to refine the Mesh quite substantially. Then it will solve, but also require more memory.
Ideally you would have created this in the Frame environment and then you could solve the Simulation when in Frame. This Meshes & solves much faster.
Siemens EMEA GTAC Support
