SSE2 Instruction Set Error
Not applicable
I get a error when attempting to install SE Free2D. The error says "cpu does not support SSE2 instruction set".
I am running XP Tablet PC Edition 2005, version 2002, Serv. Pack 3.
Can you help?
Butch P.
Re: SSE2 Instruction Set Error
Not applicable
Butch,
This is not a problem with the operating system.
It is a limitation of your CPU.
The CPU is too old to support the instruction set to run the software.
We detect this and not let you install on that machine.
Rick B.
