ST 8 and Macro problem
Master
Master
There used to be a forum for programming in Solid Edge but I don't see it now. Does it still exist?
I'll  post the problem here in hopes somebody may have seen the issue. After upgrading to windows 10 and ST8 today a macro to fill in our properties we have used for the last 20 years no longer runs. It seems the problem may be the windows UAC (User Access Control). It was not a problem under windows 7 for some reason. Possibly because all users were full admins on their machine. Not so under windows 10.
Anyone?
Leonard
Re: ST 8 and Macro problem
MLombard
Retired
Yes, there is still a forum for programming:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/bd-p/SEDeveloperForum
Master
Master
Thanks I see it now. I believe we found the issue with the macro. The macro is named Update Props and it seems anything with the word update in the title kicks off the UAC protection. Guess we will have to rename and recompile it if we can figure out how. As I said Barry Shillingford wrote it for us a loong time ago.
Leonard
