ST10 MP03
I cant install the update for ST10 (MP03).
What is wrong.
Geir
Solid Edge 2019
Betreff: ST10 MP03
Hi @Geir-Petter
try the standard procedures to solve such issues.
  • Turn Off the UAC
  • Run as Admin
  • Download the MP3 again and
  • try an unzip using 7zip of that exe, to see wether the zip file is correct
  • turn off any antivirus software
and hope that one of the above will solve it
Wolfgang
Re: ST10 MP03
Good morning Geir,
What's your current version of Solid Edge?
Theodore
Kind regards,
Theodore Turner
Re: ST10 MP03
Hello Geir,
Please see the screenshot below from a previous thread.
Kind regards,
Theodore Turner
Re: ST10 MP03
Hi Theodore,
Where do I find, about Solid Edge?
Geir
Solid Edge 2019
Re: ST10 MP03
Hello Geir,
Select "Learn Solid Edge"...it should be on the right hand side.
Kind regards,
Theodore Turner
Re: ST10 MP03
Solid Edge 2019
Re: ST10 MP03
Hello Geir,
Well, there's your problem. You don't have a released version of Solid Edge installed. As "uk_dave" stated it should be at least "107" and not "105".
You will unfortunately have to uninstall Solid Edge and install a released version.
Kind regards,
Theodore Turner
Re: ST10 MP03
Download it from Gtac?
Solid Edge 2019
Re: ST10 MP03
Hello Geir,
Yes, download from GTAC is your best bet. This will be the latest released copy.
Theodore
Kind regards,
Theodore Turner
