Betreff: ST10 Open Draft
hi all
Does it take some time to set up and index the folder? ... it does not seem to apply right away.
Is it time to reindex when adding folders? ..
Hi @Hclee
of course it takes a certain time (depending on how many files there are in the given vault folder structure) and how fast Your PC and/or drive will be.
This can take some hours too!
What I can recomment is, that You first will try it with a smaller directory structure and less files to see wether or not it will work there.
Wolfgang
