ST10 - Problem using Zoom Area & Pan on Custom Orientation.
Hello. Not sure this is right place to ask. But...
I am trying to create Draft. Used "Vew Wizard" to open 3D part. and Trying to use "Custom Orientation" to choose desired view of 3D part.
However, I can't use "Zoom Area" and "Pan" button. I could use them on ST9. I just installed ST10.
When I click "Zoom Area" nothing happened. Same to "Pan". Other button seems works. Only those 2 buttons doesn't work.
Does anyone know why? (Red circiled button doesn't work. I re-started after installation many times.)
Matt
3 REPLIES 3
Re: ST10 - Problem using Zoom Area & Pan on Custom Orientation.
Doesn't work for me either.  Please PM your sold-to id and I can get the PR processed for you on this.
Hi Dave. Thank you.
I pmed you.
and I installed ST10 on different PC and did same problem. So it must be software bugs..
Matthew
Matthew,
PR#8352831 has now been submitted to development for further investigation and resolution.
Thank you and regards,
-Dave
