ST10 Program Help Data......???...!!!
Please,
After using the Solid Edge on the continues maintenance for about 20 years I do not go to help too often but today I did want to check it due to reading the current discussion on the user group on Help.
It is 2017, I am using successfully computers since about 1986 and this is want I am getting:ST10 Help Trouble.JPG
 Milan.
Milan Wendl, MEngSc, P.Eng.
AAA Engineering, Canada
ST10, SolidWorks Premium 2018
4 REPLIES 4
Re: ST10 Program Help Data......???...!!!
You are reporting two separate issues here.
1 - Security certificate --our online help server is currently experiences issues.  This is a known and our IT team are actively working to resolve this issue.
2- Java 64-bit -- you are trying to install the local help server and need 64-bit Java v. 1.8 or higher.  Uninstall *all* existing versions of Java on your system.  Reboot.  Then install *only* 64-bit Java v 1.8 or higher.
Gears Genius Gears Genius
Gears Genius
I too have seen this in the last few days about the web site having issues.
So I decided to install the local help on my PLM Documentation Server, and everything installed correctly.
But when I press F1 the system still tries to acces the SiemensPLM webite.
How do I set the local install to access my PLM Documentation server?
Thanks ahead of time.
Few notes just to save perhaps some time to others:
- Installation of Java 64-bit, while keeping my current and updated Java 32-bit
- Doing all on above screen snip and at the end setting up my ST10 local help location shown in the attachment did the trick.
Gears Genius
Thanks Milan.
