ST10 Sync sheetmetal part ignores bend radius change
Anyone else seen this? Changing bend radius under variables or in the material table gage properties is ignored on the part?
Harri
Re: ST10 Sync sheetmetal part ignores bend radius change
FWIW this seems to appear on parts that originated in ST9
Harri
Betreff: ST10 Sync sheetmetal part ignores bend radius change
Hi @hjoy
just opend Your PSM and changed the Material Thickness without any problem.
Thickness is changed exactly according to my inputs.
Thanks Wolfgang, thickness works, bend radius doesn't. Did you mean that both work?
Harri
Hi @hjoy
Bend Radius also works perfect, but just for Your information:
For the given two bends You have set their option to not use the Gloabl Bend Radius but a specific one.
See options for them:
Deselect this button and the two bends will use the Global Bend Radius again.
Otherwise a change of this global variable will not be reflected by them.
Thank you for your insight Wolfgang, you're a true Genius!
Harri
