ST10-Technical Publications: Interactive. Digital. Associative Technical Publications: Interactive.
I watched the document and watched the video in the above-mentioned title.
It seems to be very effective document management in the manufacturing field.
However, if you change the document to a PDF file
Can I see it on a PC without Solid Edge installed?
