ST10 clone component
clone Component Clearly a good feature.
But if you like video ...
Can I select the same part at once?
youtube URL :  https://youtu.be/fU3H6-fAqlA
The key to the question
If you clone component to clone component again, make sure you can select the same part that clone already (Select all at once)
I also attached a work file.
It is for ST10.
p.s : Pattern collapse occurs when using a simplified assembly. Can someone upload an IR after the test?.
Re: ST10 clone component
You can use fence selection to select target parts. This is a suggestion.
In your case I suggest using Duplicate component instead of Clone component, it's much faster.
Your suggestion is good, I always say that selection tools are the keys in all software...
BR,
Imics
Why can not I think of this? ^^
Thank you for always good answers.
