ST5 Adjustable Part / Assemblies
I prepare some Adjustable part with two variables. I made an assembly and link the Assembly variables.
Now all the part in assembly can change respect to the variable. How prepare the single drawing for the part taking the value inserted on assembly and not from the original stored in part ?
Sorry for my English....
Thanks, Eros
I believe you would need to create an assembly configurat...
I believe you would need to create an assembly configuration hiding all other parts except for the one you want to detail and then place the assembly in your draft and specify the configuration that you set up.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
