ST5 License Renewal: Code sent to me is for ST7 and does not work in the ST5 License Manager
I have Solid Edge ST5 whose license has expired. I went to the link given in the automatic upgrade email I had recieved.
After filling in all my details I got a code but for ST7. If I start the ST5 License Utility & try to enter this code under "I have an academic code" then the "OK" button needed to proceed stays grayed out.
What are my options? If possible I do not want to upgrade to ST7 right away but want to continue using my ST5.
Any ideas?
Re: ST5 License Renewal: Code sent to me is for ST7 and does not work in the ST5 License Manager
Community Manager
@cadpanda
I will create a Solid Edge ST5 Academic license file for you and email it to your registered Solid Edge Community email address now.
(I will also send you an ST5 academic code - if you'd rather go that route.)
Let me know if you need further help.
Enjoy,
Laura
@LauraWatson
Thanks so much for those! ST5 works now!
If I may pick your brain more: My OS is Windows 7 64 bit Home Basic. Would any of the latter versions of Solid Edge Student Edition run on this system? Or do they all only work on Pro?
Community Manager
@cadpanda
Solid Edge ST6, ST7, and ST8 all should run fine on Windows 7 Home. This operating system is just not a configuration which we certify internally or formally support for production use. But  I am not aware of any problems running Solid Edge on Windows 7 Home.
Sounds like it's now time for you to give ST7 or ST8 a try.  Today ST7 is on the free student download.  We have requested IT upload the ST8 free student download later this month.
Enjoy!
Laura
Thanks. I think I will definately give a new version a shot. My experience with ST5 has been pretty fantastic.
If I could do one feature request it is that you should release more of the Piping functionality for the Student Version to try out!
Respected Mam;
                        Greetings of the day.I have a solid edge ST7 but I got Academic code for ST8.My Institute is using ST7 so for same environment I want to use ST7.Will you please help me to get the ST7 Academic code? As when I enter ST8 code the OK button stays greyed out.
                         Thanking you in anticipation!
Community Manager
@CARCRAZER
Please send me the email you received when registered for ST8 and I will use it to create you a new ST7 academic license file.
Laura
watson.laura@siemens.com
@Laura
It is time for me to renew my License again. Last year you had helped me by generating a License File for my ST5. Is it possible to send me another one this time?
I tried renewing via the online interface but unfortunately it does not have the option to generate a ST5 License File.
