ST5 Simulation units
Not applicable
Hello
I was wondering if anybody knows how to change the units in ST5 simulation.
For example, by default the force unit is mN, can i change it to N from somewhere?
All the best
Re: ST5 Simulation units
I believe you do that in the file properties, advanced units.
Sent from my Motorola Electrify using Tapatalk 2
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
Not applicable
Thanks, found it.
Not applicable
Actually you do not need to change settings, just write N at the end of value you input.
