ST5 Student License Renewal
I had installed Solid Edge ST5 about a year ago and hadn't used it much recently. Today when I tried using it complained that: "Feature has expired: Solid Edge Academic"
What's the right way to renew the Student License. i just re-registered and have the email with a new License Key but where do I enter that into?
Re: ST5 Student License Renewal
Hi there,
The email should give written instructions on how to use the new "academic code".
....but, if you "copy" the code in the email, then go to All Programs > Solid Edge STx > Licensing > Licensing Utility, the select "I have an Academic Code" radio button it will display a field you can "paste" the code in....you should be good to go.
Solid Edge ST10 [MP7] Classic [x2 seats]
Hi
I have a little problem, i get a e.mail with the Academic Code but it doen´t works.
I can´t push the OK button...
I should get an e.mail with an (*.txt)  but i only get the code and this one doens´t work.
Thanks for your help.
